DandW
I have an old Case 580B. Its been real good to me but I had a problem today with two pins that won't take grease. The one I got to work by replacing the grease nipple and spraying some SeaFoam in it. I let it sit for a while then once I put some pressure on the grease gun I heard a pop and it started taking grease. The other problem pin is on the bottom of the yolk of the backhoe section. It is the main pin at the bottom that the whole back end swivels on. I tried the same thing with it but it didn't work. I even cleaned all the old grease out and heated the pin up with hopes that might release the bunged up grease blocking the holes.
Anyone have any tricks or advise they could offer ?
I really don't want to remove the pin to fix it if possible, that's a fair big job and I was hoping someone might have a trick up their sleeve ?
Thanks
Dave
Thanks
Dave
