Funny farm
- Joined
- Apr 21, 2018
- Messages
- 206
- Location
- Ontario Canada
- Occupation
- Red seal,high pressure certified welder
hoping someone might be able to help. having a hard time getting fuel primed after pump change.
short history:
this spring i overhauled the engine and re used the inj pump. ( donor engine for the rebuild also had a pump with it ). the orig pump worked fine. but has pieces of flex ring inside the timing window and leaks from the throttle shaft a good bit. but i used it cause i k ew it worked even tho it leaked and was tired.
started to notice the oil level rising slowly. changed the oil and kept a closer eye on it. after only 8 hours i have gained a good half inch or more in the stick so i suspect the umbrella seals to be leaking and causing the dilution and oil level rise.
since the pump had to come off to change the seals i decided to install the other pump since it looks to be much cleaner and better looking than the orig. has no sign of flex ring pieces.
so i set the pump timing up. and drained the fuel system. removed the pump and the shaft seals.( they looked perfect to me ). installed new seals on the shaft. and installed the other pump on the original shaft. ( checked the pn on the the shafts and they matched) timed pump and connected the fuel lines. opened the fuel shutoff and bled the filters no prob. wasn’t getting fuel in the pump body tho. i had checked and cleaned the inlet screen prior to installing. am getting good flow to the pump inlet. rigged up a cap and put a couple 1-2 psi on the fuel tank and very slowly the fuel comes up in the pump body. is that normal? or should the pump body fill faster. i put a bit of lucas cleaner/ upper cyl lube in the top ( with top cover off) and some clean fuel. but nothing from the inj lines. gave up at 12 am and this morning the body was full. drained the pump via the timing window to check the free movement of the metering valve. seems free and fine. double checked the flow of fuel at the pump inlet and again having an issue priming the pump and getting the inj lines to bled.
should the pump fill slow? cranking the engine did t seem to pump much into the housing.
this pump appears to be in better shape all around. pilot tube has less wear grove. pump body is clean and not covered in 6 layers of paint. but can’t seem to get it to prime/pump. have checked all the things i could think of and find online but hoping the pump guy or someone who knows pumps better can point me the right way on how to prime this pump and if the slow filling is normal even tho there is good supply. return was also checked and clear of obstruction. neither pump have a check valve and appear to be identical fittings so i suspect they never had that. but regardless the return is clear to the tank. don’t know if i should take the orig pump and this pump apart. order a seal kit and attempt to repair the one in the best condition. i can’t afford the 900 dollars the local shop quoted to rebuild one. fairly confident with the stuff i have watched and read about these old pumps that i may be able to do the re seal myself. i have a mic and can measure the rollers. but i don’t claim to know what i’m getting into and if i could tackle it or not. i figure worst case i have to save up and have one of them done professionally and i’m only out the time and 49 bucks for the seal kit if i failed. i’d be sure to have something ready to choke it out if she started and ran away after rebuild hahahaha. hope to get back to working at it tho aft and weekend. would hate to condemn this pump as bad if i’m not doing i’m something right or if there’s something minor going on. the pump has sat for an unknown time. it did have clean fuel inside. or at least decent looking for older fuel. didn’t sit dry at lest. thanks in advance for any insight and help.
short history:
