Cat E70B Hyd Thumb Install
dieseldog5.9
New Hampshire
Old trusty Cat E70B has a manual thumb, would like to make it a hydraulic thumb looking for information to plumb into the valve bank on this machine if it is possible.
SN 7YF01328
bindian
Willis, Texas
Aircraft Mechanic
If it is like my mid 80s E70, that would need major replumbing at the valve bank. When I plumbed my hyd. thrumb, I installed an electric over hyd. diverter valve and plumbed the bucket lines to it. Now when I want to close the thumb, I just push the button my right control stick and move the control stick to close the bucket.
hugs, Brandi
uffex
Lincoln UK
Admin
Good day DD
Please see attached may help you.
Kind regards
Uffex
  • H2 Thumb control 1.pdf
check
in the mail
The previous owner of my 1992 E70B installed a hydraulic thumb. Here are pics of the plumbing;
check
in the mail
And here is the solenoid valve he mounted below the radiator. it is controlled by the switch on the right joystick and the hoses go to the pilots on the third section of the main valve bank.
