2013 New Holland l220 Won't start. Code 3088
Adrianvz
Wyoming
I have a 2013 L220 with 1300 hours which was running fine till i parked it for lunch. Came back and the machine won't start. Doesn't even crank. A stop light can be seen on the information pillar and the code 3088. I have a service manual, but it does not show that code. Any ideas or solutions?
KSSS
excavation
If that particular code isn't in the book, I would call your local NH or CASE dealer and have them look it up for you.
Bswwood
Utah
3088 is crankshaft speed sensor signal invalid, also explains why it will not try to start. Might be a bad sensor or just the connection at the crank speed sensor.
Adrianvz
Wyoming
Hi thanks for the reply. Do you know where the sensor is located on the engine?
Bswwood
Utah
I'm not that familiar with the engine you have but should be easy to spot. It may have both Cam and Crank sensors, usually black plastic and held in with just one bolt on the side of the engine block. Hopefully the dealer will help with the details.
Adrianvz
Wyoming
Thanks again for the help. It turned out there was corrosion in one of the fuse boxes in the cab. Removed the relay and cleaned the terminals and the machine fired up.
