David Boreham
Probably a dumb question, but... I want to establish "negative slope" around some buildings where the original builder didn't (with not great results when 3ft of snow melts all around). This means establishing a surface grade that is flat, but not quite level, consistently. I've seen fancy tilting ditch buckets used for this but I don't have one of those. I am guessing there is a trick to this. Two ideas come to mind: 1) pull up some dirt such that when the machine is driven onto it, it is at the required angle vs horizontal, then grade away using a regular ditching bucket (which I do have). or 2) grab some solid length of something (e.g. a 6x6 or angle iron) with the thumb, at the required angle, use that as a grading tool with the machine level. The need to position the machine somewhere on a line perpendicular to the slope (so it can grade the slope) I think favors approach #1: you would drive forward progressively grading and after the initial few ft the machine would be sitting on previously graded soil, hence at the right angle to continue.
I'd appreciate any advice on the right way to do this. Thanks.
btw I'm doing this work with a 3.5t mini excavator
