I finally have an update on this hunk of junk. A service tech at Dallas Cummins was kind enough to find a parts breakdown of the offending balancer. With all our rain, I am getting some backlog and stale projects out and I made a call to see about parts. The balancer needs a shaft, 2 flyweights, and several needle bearings for a rebuild. NO ONE I talked to had EVER seen or dealt with one of these! Here is the kicker; the shaft is $1,100 and no availability. Best the parts man could tell me is it would be a build to order item! At this point, I decided to see if it could run without it as a Shibaura engine I just put a crankshaft in could, I was told, be run without the same style balancer. To verify my idea, I got through to a Service Tech out of the Ft Worth shop who also had never heard of or seen one. He said it would likely throw a rod as this engine is externally balanced (balancer unit) instead of a crank snout harmonic balancer and internal crank balancing.
So... now on his concurence to mounting and drive parts interchanging with a 4BT, I am now in search of a complete running 75HP non turbo engine to drop in and be done with it.
