When I broke the chain adjuster bolts from having the left side drive chain too loose I tightened the right side so it wouldn't break the adjuster bolts. My machine uses one #100 drive chain on each side. I thought I had it adjusted pretty good and there was play between the wheels. On taking it apart I must have had it a little too tight and has caused the wheel motor to leak into the chain case. I ordered a wheel motor from Loader Parts Source because in most causes internal damage causes the motor to blow out seals. I guess the best case is the motor can be repaired reasonably and I'll have a spare. Trying to do preventive maintenance backfired. In hindsight I'd rather have the chain adjuster bolts break. It's a an easy cheap fix. Going forward I'll tighten the chain just so it doesn't slap the bottom of the chain case when I rock the wheel back and forth when it's lifted off the ground. I've heard of chains breaking in skid steers which would be better than replacing a motor but would take a lot to break a #100 chain. Just kind of kicking myself. What can you do.
