I have a Case W20B with an Allison TT2221-1 trans. It has always struggled to get up my driveway (about 15% grade), and I just would deal with it. Now it refuses to dig going up a very small incline, and it can't make it up my driveway. While roading it: going up a grade it slowed way down, but the engine rpm's remained high. Going down a grade, it sped up, but again the engine rpms did not change. Is the torque converter bad??
The parts and Op manual says that this machine should have a 4 speed trans in it. It only has a 2 speed. I'm guessing it was swapped out before I got the machine. If the trans has to come out to get at the TC, should I look for a 4 speed to put in it?? If so, what model #.
