K&k land management
my injector pump went and I need to get the machine loaded and moved to fix it. What’s the best way to go about getting it moved and loaded on my trailer
Well my only choices then is to drop the tracks to get it on the trailer or remove the gear on each final drive to make move able then?
Yes has been diagnosed.. Alil water in fuel and previous owner must have been hauling fuel with some metal fuel tank cuz I got rust all through my fuel system. The tech don’t want to do it where it sits. He wants it under cover well doing it.
If it is on dirt,grass or something like that it will slide and if trailer deck is smooth as well. Just need to get something big enough to move it.Well my only choices then is to drop the tracks to get it on the trailer or remove the gear on each final drive to make move able then?
That winch might be able to move it,but it would help if something could help pushIt’s on gravel right now I have a tilt deck wood deck trailer figured I would hose it down put dawn dish soap on it make it slick. Do you think a 12,500 pound winch will drag it on the trailer
Use a two part line on the winch. It will move it as long as the winch stays anchored.It’s on gravel right now I have a tilt deck wood deck trailer figured I would hose it down put dawn dish soap on it make it slick. Do you think a 12,500 pound winch will drag it on the trailer
There are or should be tow valve levers on hydro pumps so you can push or pull machine without damaging hydrostat pumps and motors.
