finally got it running. still have a problem with the fuel shut of valve as it will not open but with the key on you can open it manually and it will stay open and close when you turn the key off. fuel gage, temp guage and voltage gauges all work, theres a red light that comes on when you turn the switch on. goes out when it starts so I thought it probably was the oil light. what is the other light right beside it. thanks norm
