Chris Sulentic
I have the following questions about GREASE...
1. Do I need to move my case of grease inside to avoid freezing temps in the winter?
2. I try not to overgrease, but does it cause any serious problems?
3. What to do if your grease gun gets caught on a zerk? I broke a zerk fitting some time back trying to get the grease gun off the zerk, and it royally p'd me off. Made me a little gun shy.
4. I assume you can mix synthetic with non-synthetic grease 'cause how are you going to do it otherwise if you change from one to the other? Do you never change? I know the simple answer is to just follow the manufacture's directions, but would like a deeper answer if there's one out there please.
Thanks in advance,
Chris
Thanks in advance,
Chris
