Hello,
I was recently cleaning my 2011 CASE 440 skid steer. Spraying it down and I got water in and around the fuse box in the cab on the left hand side and pretty wet around the wiring under the cab. I heard a couple of high pitch beeps. I thought everything was fine until I fired it up again. It is running normally but the hour meter went from 1012 to 6889. I thought maybe it would go back if a connection was wet that needed to dry out but its been sitting in the sun now for two days and has not corrected. Anybody experienced this or know how to fix it?
