Paint for inside gaz tank
ronbourd
rimouski
I just finished removing rust and dirt inside a gasoline reservoir. Can some one suggest me a good paint for inside the tank, a paint that could be found locally. This is for an old motorcycle! thank you for yours reply! Ronald.
I had very good luck with Caswell tank sealer on the old Farmall BN.
https://www.caswellplating.com/epoxy-gas-tank-sealer.html#
Not sure if they ship out of USA but worth a check by email.
I was lucky as they are only about an hours ride from me and got a discount for paying cash when I picked up at the shop. Even comes in a few different colors! Being a Farmall I "had" to use the red stuff!
Former Wrench
Montesano, WA
Retired
Years ago I used a 2-part product for a rusted motorcycle tank. It's been years so I am a little fuzzy on the details and product name. The first dose cleaned and etched the tank. Then the second batch went in that when dry, formed a seal that was a layer about 1/16 in thick. The stuff worked good. You might ask around at a bike parts shop.
One thing that can not be said too load or too often:
No matter what product you decide to use preparation of the tank is the number one most important thing to a successful repair.
Tugger2
British Columbia
Ive sent tanks to the rad shop. They boil them clean in the hot tank . I believe the coating they used was called Glyptol.
Bls repair
S E Pa
Equipment operator,mechanic
Kshansen
The options I see are cleaning tank or wife divorcing you:eek:
Tugger2
This is the method I’ve always used.
Some what OT here is when painting small parts backing in oven at around 200-250ºF works great and hardens the paint. Just don't do that in the kitchen unless wife is out on a 2 week vacation to give time to air it out!
The solution is to buy a new stove for the kitchen and move the "old" one into the garage/shop. One other good point about having the "old" electric oven in the garage/shop is if you have a small portable gen set you can use the stove as a load bank to test the generator so you know it's good to go when power goes out! Turn one burner on at a time to adjust the load.
ronbourd
rimouski
Thank you for all your reply, finally, I used "Gold Standard TANK SEALER". The job made a very good result, the gaz tank was built in 1967, a small Yamaha motorcycle! Ronald.
