I have an Eaton/Char Lynn drive motor leaking into the chain case on my skid steer. I replaced the other motor several years ago for the same reason. They said there was internal damage so it wasn't worth rebuilding. Reading online it says most leaking is caused from internal damage and is rarely fixed with a seal kit. Should I just order a new drive motor or hope to get lucky? About 4200 hours on the machine. I've done pretty good maintenance on the machine and changed the hyd. filter regularly.
