DaddyK
My 2003 Takeuchi TL130 is showing a low coolant/low oil pressure light on start and trips a master warning and shutdown after 10 seconds or so. I have no unusual noises leading me to believe the oil pressure is fine. The only wire I see on the coolant lines is a single blue wire in the lower radiator hose. Is there a way to test the sensor before I start to throw money away on a new sensor? Also I understand from research that there is a method to bypass the safety “auto shutdown” to allow me to at least get it running so I can use it. Can anyone offer some help to find the bypass wiring plug and troubleshooting the coolant sensor?
Thanks
Thanks
