Genie Z60/34 boom will not retact via platform switch
Abita Springs LA
Hello all,
I have an older model machine and not sure of the year so see picture below. A few weeks ago my boom retraction switch on the platform began to malfunction. All other platform switches work. You can hear the machine 'engage' when the platform switch is applied so thinking this may be something simple if I know where to look? Thankfully the boom can be retracted from the machine control board but that is not convenient. See video showing the exact issue.
gatorsby7
dunnellon, fl
retired
my 1995 Z45 service manual troubleshooting section has a flow chart of what to test for when boom down function is inoperative from the platform. do you need it?
skata
midwest
genies can be wierd like that. sometimes you can get a stuck function to work by doing another function at the same time.
Abita Springs LA
gatorsby7: that would be a start. Although I have worked on equipment and vehicles for years I know the wiring diagrams are a bit more complicated than what I am used to but I am willing to give it a shot. Also, I did a video of the inside of my machine control panel and posted it on your thread. If you need some closer pictures or a video showing something in particular let me know.
Abita Springs LA
skata: You know I didn't think of that but what is the harm? If it doesn't 'jack up' anything by hitting multiple controls at once (and it shouldn't) then I may have success.
gatorsby7
dunnellon, fl
retired
