DRO for milling machine
farmerlund
North Dakota
Farmer/ excavator
Hey guys looking for a DRO for my Bridgeport. I don't need a real complicated setup. I would like the ability to set up holes in a perfect circle. PCD function I think its called? What's the better glass scales, magnetic? pros-cons.
I have seen $150 kits and $1500+ kits I just want something decent and easy to use. Remember I am the weakest link in the operation. Was looking at some thing like this.
Thanks for your help
https://machinetoolproducts.com/ditron-d80-3-axis-mill-dro-kit-w-glass-scales
gtermini
Amity, OR
Newall with the magnet ball tube scales are very easy to install and hold up well against dirt/oil/grime I think DP500 is the lower function model. About $700. User interface is easy. I have DP700's on 6 mills in the machine shop. All hold thousandths easily.
I never use PCD for bolt circles only because I've memorized the trig values for 3/6/12 and 4/8 patterns. Just zero on the center and don't worry about whether I keyed in something wrong.
3/6 is (X=.866*radius, Y=.500*radius) & holes at (X=0, Y=radius)
4 @90 deg straight is (X=radius, Y=0) & (X=0, Y=radius); 4@ 45 deg is (X=.707*radius, Y=.707*radius)
farmerlund
North Dakota
Farmer/ excavator
I discovered my Bridgeport is predrilled for a Acurite set up so I am thinking of using them. haven't ordered it yet.
