bobcat ron
Banned
That must have been a "bad B" model, they fixed the lag time, they used bigger diameter hoses in the pilots soon after the complaints started, the new B2 series are really nice, or else I wouldn't have bought one.
Are you saying that it is ok for Cat to fix a design flaw & be expunged from their mistake? Yet if ANY other brand happens to have a design flaw that is subsiquently re-engineered, they are eternaly doomed to being junk by the likes of yourself?
I understand that you are proud of your overpriced, lemon colored, machine but why all of the ridiculous bashing of anything that isn't a 247B2?
And.....I stand to be corrected, enlightened, and educated.
Twisted
I can tell you exactly what your problem is, its a loose belt to water pump trust me!!!!!!I have had a 1300HD for several years. It has never been a daily runner but is has served me very well. Operating expense is very cheap. Some have mentioned visibility as a problem but it is much better than my Bobcat 753. As long as the bucket is good and tight I feel you can meet any grade tolerance. The 47hp Kubota V1902 is not the easiest to start in cold weather but it has to be really cold (single digits) before needing to use starting fluid. My research attributes this to the indirect injection and glow plugs used. As far as cracks or welds the only problem I have had is the left boom arm directly below the remote hookups. The weld has cracked repeatedly but has never gotten into the metal. I am going to put a thick piece of plate with a good fillet and radius and see if that fixes the problem.
These are very simple machines. The plug in wiring harness that goes from the engine compartment to the cab had worked loose a few times but it was an easy fix with a couple of strong cable ties.
This machine has around 6000 hours and the engine supposedly has around 2500 hrs. Last summer after working it for approx. one hour or more really hard the temperature would rise to around 205-210. I have checked everything I know to check and cannot figure it out. I even replace the radiator with a larger one I had. What is most strange is all you have to do is open the engine door and the temp drops back down to 195 very quickly.
Can anyone out there help?
