An aftermarket one matching the rest of the aftermarket undercarriage on the tractor would be my best guess.
Poor quality material maybe..?It appears I have about a 3 inch crack half moon shaped on my front idler? Any ideals what would cause this? Are if it could be welded without take it off?
Can I use a TO-2 in this machine? I believe that was what was use when it was new?For your location TO-4 SAE30 would be the appropriate oil. Use a good branded oil, not stuff from your local parts house.
Regarding level are you checking it "per the book" with the transmission oil at operating temperature, engine idling, & transmission in neutral..?
Your dipstick may have markings on both sides. If it has, then one side will be "Engine Stopped - Oil Cold" (what you should check before starting to make sure the machine is safe to start) and the other "Engine Idling - Warm Oil" or something similar. The second one is the more reliable level check.
If you haven't changed the oil and filter since acquiring the machine now may be the time to do it, just so you know what you have.
This crack looks like it may of been from a 3" hole, the idler appears to have a lot of meat on it, was wondering if this could be the patch from a drilled hole cracking?I did work experience in a shop that used to build up idlers 24/7 with the sub-arc process. They cut about a 3" hole in the side of the idlers so they wouldn't build up with pressure from the intense heat of welding. You could always tell if an idler had been built up if it had the plug welded back on the side. I welded a crack in a ripper frame and it cracked on cooling for the same reason. I should have left a small bit un-welded until it cooled and then finished it. It's not much different than a car tire gaining pressure after driving but with the welding there is 100 times the heat input and 100 times the pressure build up. I don't think drilling a vent would provide a fast enough release of the pressure. The crack in the new idler is odd.
You are correct, TO-2 was the specified oil when the machine was new. However you may struggle to get TO-2 oil today, almost 20 years after TO-2 was superseded by TO-4 which has a higher performance specification.Can I use a TO-2 in this machine? I believe that was what was use when it was new?
