Lift worked fine last fall. Both on Propane and Gas. Sat for 4 months indoors and now is difficult to start on gas, won't run on propane at all. It will crank and fire for a few seconds. I checked for fuel pressure on the fuel rail and nothing. checked for codes and get one blink, then two blinks over and over. I have replaced the fuel filter and flushed the fuel tank and refilled with fresh gas.
I could use some direction. Where it was stored, no mice could get to it so I don't believe there is chewed wire.
