mattyt1984
2002 international with 444e. Starts hard when cold has a slight miss at idle. Has low power. When I scan it Shows code Sid0254 and says abnormal frequency or pulse width or period. Also says 6 current above normal or grounded circuit sid 254 controller #1.
I tested all cylinders with an infrared after several minutes of running the drivers side front only is about 100 degrees the one next to it 2nd back from drivers front is around 130 all other cylinders are about 180 degrees. Im thinking injector in the driver front?
Any ideas or things to try?
