mechturman
Dear All,
Currently facing an overheating problem on D5H, S/N:8RC01817
Transmission doesn't engage in low throttle, you must increase at least 1200 rpm. When it gets too hot, customer must give full throttle that he can engage transmission. After 30 mins operation, TC temp gauge reaches to 130°C, if you would go on further it reaches to top, red warning light starts to blink.....My pressure readings are:
PUMP PRESS (PRIORITY PRESSURE) : 450PSI
TC INLET PRESS: 130PSI (when oil is cold), 80PSI when hot oil.Is it normal this? I mean when its cold on press chart it says max 145 psi for protecting TC coz of cold starts. Ratio valve was stuck before I took trans main valve and corrected, now it is working fine.
TC OUTLET PRESS: 62 PSI
P1: 350 PSI
LUBE PRESS: 20 PSI.
TC STALL SPEED : 1800 RPM.
I drained oil from TC, and it is about 5-6 litres. But I found some magnetic particles, I don't know they are ALU or not.
I checked metal tube from xmsn case to TC inlet and it seems OK.(not cracked)
Transmission oil cooler and TC are new installed.
What about your opinins,currently I am thinking to pull out TC, disassemble and see whats inside.
P1: 350 PSI
LUBE PRESS: 20 PSI.
