I had one, older series, non-turbo model. for what you are saying you are going to use it for, im sure it would be fine. Super nice to drive with AWS. The non-tubo was defiantly on the under powered side, I think almost all of them are turbo. Have a tenancy to rot out under the doors/floor boards. Mine (being the older side) had leaf springs in the back and was a little rough. The loader arm was not designed to dig out a basement.
All of that being said, it was a treat around the property. Enclosed cab, super easy to use, super easy to see out of. Nice tight turns, I do miss it a bit.
