The 8x8 forwarders with the separate crane might have a lower center of gravity than a Timberpro clambunk for the hills. Probably fairly expensive to run a timberpro with a widedual setup of 16 tires.
Might need to put a winch on a 8x8 forwarder/ clambunk to pull wood on the hills. A fast travel speed of the multiwheel skidders is the tigercat 625E (230hp)
There have been Komatsu 895 and John Deere 1910 forwarders down south. Possible to convert these to clambunk configuration
https://www.komatsuforest.com/forest-machines/our-forwarders/895-2017 (no twist cab)
Komatsu 865 8x8 Clambunk (no complexity of the twist cab on the JD)
JD1910g 8x8 forwarder 268 hp (complexity of the twist cab)
John Deere Forwarder/ clambunk mounting plate pictures
https://www.utilajeforestiere.eu/produse-forwardere-forwardere-clambunk_en.html
https://www.hsm-forest.net/hsm-208f-14-to-steep-slope.html , Looks solid in the crane, 238hp
HSM 208FC20 steep slope clambunk forwarder - trees a bit match sticky. - BC, Canada
Also the tigercat 8x8 1075C (308hp) forwarder could convert to clambunk, 1075C faster travel speed transmission than a 1085C (308hp) (used in the steep southland gum blocks) . 1075C low 0-3.5 mph and high 0-11mph
