Engine Serial Number JRE07538 does not associate with a machine in SISEngine No. JRE07538
The dealer told me that was installed at wheel dozer ..
If you Have SIS could you please check if it was ?
C15 JRE07538 Arrangement 241-0020
BUILT DATE 02/04/2008 TEST DATE 06/04/2008, SHIP DATE-unknown
AS BUILT
C15 DTI11 OLD-C15 ACERT DIT ATAAC IND11
MWCODEA - PRIMARY DRIVE
HP00475 - 475BHP (354BKW) W/O FAN
PR-5367 475 BHP WOF 2100RPM (B)
MISINDOE - INDURTRIAL/OEM
CERTIF5 EPA/CARB TIER3 / EC STAGE 111A
Parts List does show Air Compressor Group, so the engine could have been installed in a wheel dozer.
Question to answer: Why did number 6 connecting rod bearings fail? Were Main bearings shells installed upside down? Shutting off oil flow to the #6 connecting rod bearings.
Regardless if Non-OEM parts were used to rebuild the engine, IF the parts were installed wrong the engine will have a failure.
