OldMachinist
Pardon the obvious newbie question. Under my JD 450H and looking to change the engine oil. There is an access hole in the belly oil pan cover that seems like I can drain the oil through. There are two "drain" bolts in the back end of the engine oil pan. One sticks straight down from the oil pan and the other sticks straight out the back of the pan a few inches from the vertical one. Which is the engine oil drain plug? What is the other one for?
Thanks so much.
Thanks so much.
