How to replace the wheel speed sensor on a Deere CT332?
gumper
New Jersey
I need to replace the wheel speed sensor on a 09 John Deere CT332. Can't find much information in the Technical manual. Do I need to remove the Track and Drive motor to get to the sensor?
Thanks,
Gumper
gumper
New Jersey
Great, thanks for the info. Do you know if I will have to do any kind of calibration once it is installed?
Thanks,
Gumper
mg2361
Pennsylvania
Equipment Mechanic
Technically yes, a hydrostatic calibration should be performed. But I would try without the calibration. If no codes pop up, its not jerky and it tracks straight go with it.
gumper
New Jersey
I finally got some time to replace the sensor. It went well, but I'm still getting the same error code (says bad data) and the computer shuts down the tracks from moving. Is there something I have to do to clear the codes?
Thanks for the help.
Gumper
gumper
New Jersey
There are 2 active and a few stored. The active ones are 2661.14 (Right Joystick, Y-axis) and 2698.14 (Left Joystick, Y-Axis)
The Stored are 190.12 (Engine Speed Sensor), 1594.02 (Left Speed Sensor Input), 2698.14 (Left Joystick, Y-Axis), and 2392.05 (backup alarm)
I wonder if maybe there is corrosion on an electrical connector or 2 that might be sending weird signals? As soon as I start to engage the drive motors, the computer shuts all movement off.
mg2361
Pennsylvania
Equipment Mechanic
Possible. Odd that both left and right levers would have the same error. make sure all your connections are sound. Power and grounds are good, especially to the Monitor and the Joysticks. I attached a few items that might help. Next post will have a couple more.
  • 002661.14 - Right Joystick Y-axis Sensor Redundancy Error.pdf
  • Boom and Bucket Calibration—EH Controls.pdf
  • Engagement and Monitor Unit Circuit—EH Controls.pdf
  • Engagement and Monitor Unit Data Items.pdf
mg2361
Pennsylvania
Equipment Mechanic
And these.
  • Hydrostatic System Calibration—EH Controls.pdf
  • Joystick Schematic.pdf
