r20d12
- Joined
- Nov 29, 2009
- Messages
- 123
- Location
- oklahoma
- Occupation
- heavy equipment field tech since July 1990
Yes! I miss understood you earlier. OP has no stand by pressure on either mains, so it’s either both unloaders just fully opened up at the same time ( which is highly unlikely), or we don’t have any flow from pumps. Since i don’t know CATs I’m wondering if the pumps can be fully destrock by PRV valve at least ( maybe ) when arm rest is s down, and there’s pressure switch somewhere on pilot line which sends the signal to an ECM which in turn adjusts the PRV signal pressure to “stand by” flow. Otherwise I don’t see purpose for thes unloaders!
I like how you used "WHICH IS HIGHLY UNLIKELY". That's a joke with my CAT friends cuz the old guys blamed the ECM for everything back in the day. Cat had so many good ecms returned for warranty they started putting that in the troubleshooting section. They go down the list of possible causes then at the end it says failed ECM "WHICH IS HIGHLY UNLIKELY" LOL everytime one of us truly suspects an ECM. The others will say which is highly unlikely. Goodtimes!
