John Shipp
That Matriarch MT50FH looks good, having a look for some more pictures of it
Thanks Hank R, yes a few months ago we decided to buy tickets for plane, and come have a look. Been wanting to ever since came across this forum!Hi John, Camptramp stopped in this morning and said your coming to Canada in a few weeks sure hope you have a great time visiting some of our logging shows.
I hope you took particular caution reassembling the cover plate. They have a steel button that sits in a recess in the centre so the ball on the sun gear run against. Anyway then you knock the plate back into the hub that button can fall into the gears and you will have know idea until the machine moves. It's all Diamonds or Stones.View attachment 183836 View attachment 183837 View attachment 183838
Resealed the cover plate on the Nabtesco final drive while waiting for radiator recore. Had an easier time getting the wire out of the groove than I'd anticipated, probably could have left track on as it turned out but did have better view this way. Was expecting a lot more struggle, this one was the wire in a groove similar to a internal circlip.
Tones, I hope the caution I took was enough too, I cannot remember now exactly how it looked, but I recall a shiny spot on inside of cover plate and maybe a ball on the end of the sun (?) gear. It has done maybe a hundred hours since so hopefully I've got it back together safely....I hope you took particular caution reassembling the cover plate. They have a steel button that sits in a recess in the centre so the ball on the sun gear run against. Anyway then you knock the plate back into the hub that button can fall into the gears and you will have know idea until the machine moves. It's all Diamonds or Stones.
