donald noel
Was clearing trees the other day when the thumb stopped working.
Here are the symptoms: Trying to extend the thumb would get it to slowly move about an inch. The RPM at ¾ throttle drops about 300 when the extend button is pushed. Holding the button keeps the RPM low. Retraction works as normal.
All other machine hydraulics work fine. No visible leaks at cylinder or valve stack. Hydraulic tank at normal operating level.
Opened the fitting at the base of the cylinder and the thumb dropped with gravity. Let it fall about ½ way then closed the fitting and it still would not extend (close), but retraction worked normally.
The cylinder isn’t binding, nor is the thumb itself. I’m guessing it’s a valve issue but not sure how to verify.
