AUSTOUGH GRADER
G,day Guys,
I have a DRMCO D600 grader with the 9138 ( I think, no serial no plate attached) transmission. And for the second time Since i have owned it the power shift in reverse has failed again. It seems as though I can’t reverse in any gear higher than 1st or it locks up. Anyway was just seeing if anyone else has had the same fault. Also is there an upgrade transmission I could possibly fit in its place, maybe a later model trans. Look forward to your reply.
Best regards Will
Best regards Will
