Quick run down of machine. 2001 TMZ34 SN T3401-7. The machine sat for years and only has about 25 hours on it!!! Retained the original green boards. Put some new gear (batteries, charger, fluids, etc.) in it to get it back up to speed. Boards seemed to be nonfunctional, so sent them out for repair. The machine worked PERFECT after I ran it for about 20 minutes and put it away. Did another test the next day; I powered it up and just began to beep on and off (long beeps and every couple seconds). Only the left/right platform seem to engage motor and the lowering functions seemed to open valves. Battery level indicator was functional. The level LED functioned and would go out when the sensor was manually tilted. No other functions work.
I tested and verified voltage at all the common points.
ANY ideas or direction?
Blue boards are not available and the newest replacement/fix is at $4700!!!
