StumpyWally
- Joined
- Oct 21, 2011
- Messages
- 516
- Occupation
- PE Civil Eng'r, Computer Sys. Mgr., Retired
Improvement #28 - Extension Cables on Diode Connectors
Recently I had problems with the interlocks on my machine (see this thread https://www.heavyequipmentforums.com/threads/nh-l220-interlocks-have-me-defeated.71899/).
In the course of finding the cause of the problem (mouse chewed wire!!), I learned that there are 4 diodes in-line in the wiring harness under the cab on the left side. According to others on HEF, they have been the source of many electrical problems, since they are prone to corrosion & otherwise failure. See this members experience here https://www.heavyequipmentforums.com/threads/new-holland-l223.72081/.
The connectors are in an almost impossible location to get to & work on. Even though they turned out NOT to be my problem, I decided to put extension cables on the connectors for future serviceability. Here is a photo of the 1st 3 diode sockets with the extension cables plugged in & the diodes plugged into the end of the extension cables, labeled, & wire-tied to an adjacent harness:
The 4th diode socket is about 8" to the rear of the above 3, & is even worse to get at. Here is a photo showing the socket with the extension cable plugged in & wire-tied to the loom.
Here is a photo of the other end of the 4th extension cable with the diode plugged in, labeled, & wire-tied to the top of an adjacent harness more in the open:
Each of the extension cables is a 2-prong trailer connect cable, about 16" long, from NAPA, part # 784640. Cost for all 4 was about $22.
