Finally bought a gooseneck and can haul this thing. It's been throwing a code since I've owned it, "2950.05 , Suction Air Throttle Actuator , out of range low", I have not been able to find any info on what to do to fix it. Accelerator pedal also seems to be not working well, I usually just set the throttle with the knob. I called two local dealers, both said they would get back to me about that code and never did. This thing goes thru a lot of hydraulic fluid and I can't seem to track the leaks, although I know where the oil is leaking, drain bolt connection to the outside port. Anyway, I plan on taking it to a dealer. I'm between three dealers, Terrell, Sulphur Springs and Mckinney Tx. The one in Terrell is small and is listed for just Ag equipment, but they said they service the yellow Deeres as well. Never been to Sulphur Springs, probably 10 mins further, also does not sell yellow. The one in Mckinney is by far the biggest and deals with yellow and green Deeres, but is probably 30-45mins further away. Any recommendations?
