rmllarue91
Hey hef I got a good one here d8h 46a 16xxxish just put new bearings seals pinon and ring gear set preload backlash on bevel gear shaft pressed hubs on with new cat tooling tried to do a nice job. Back it out of shop clutches won't release used cat assembly lube to hold the white piston seals in place. At idle 265psi going down tubes to clutch packs. Last two I did with the grease and they took alil bit but did release. Put 7000 psi on ram witch came out to 37 tons on 55 ton press. And about 1/8 recess from hub face to bevel gear shaft face. Could the grease still be holding the seals? Is there away to breakdown the grease? Do I just like kicking myself? Thanks hef can't wait to here from some of the experienced bucks if this does happen or did I miss something up... Any insight welcome thanks hef
