chris allen
Our machine is giveing us fits. Our elevator will opperate in reverse just fine but barely moves in forward position to load. Have to get engine rpms really high to barely get any forward movement. Only moves in the high position An nuthin is the slow speed Have pulled the valves outta the elevator valve body on fender behind cab to make sure nuthin was stuck An didn't find anything outta wack , both metal tubes that run up the hitch to the elevator drive motor are sitting there chattering like crazy while just sitting there Sounds like both lines are working against each other. There's 2 small lines that go from the elevator joystick control valve to behind cab to big elevator control valve body. I tryed switching the 2 lines with each other to see if it reverse functions but it made no difference in operation. Any ideas
