All of you talking about the 'excite' wiring; is this the same wire as going from the ignition switch, thru a voltage regulator and then into the brushes in the alternator?
I've driven at least 100 different cars and trucks, and none of them with an alternator ever had any pushbutton to get it charging. It does that automatically when the 60 watts of power start flowing thru the rotor. It's about a 5 amp draw thru the rotor. Most alternators have a field terminal; that's the rotor windings, output off the stator, and the bulb circuit terminal.
The charge light circuit is power from the ignition switch into the bulb and it grounds in the stator, which is the output of the alternator.
When the alternator starts charging, there is 12 volts of power coming back up the wire to the bulb. With 12 volts on both sides of the bulb, no current flow and the bulb goes out.
This is what Franklin2 was talking about, but didn't include exactly how the bulb has the same voltage at both ends.
I've read about the GM single wire deal, those have to be turning 2K rpms? to charge.
I've heard about exciting a generator that has a permanent magnet instead of an electro magnet as in an alternator. But alternators don't need that.
