RangerJake72
question for any of you out there with more mechanical know how than I. I operate a 2007 JD 650J LGP (see avatar) configured as a Fire Dozer (Tractor-Plow). Engine currently has 1939 hours on it. On the last couple of large fires I was working, starting having an oil pressure issue. OP normal runs on the high side of the dial (upper 2/3rds). On several occasions, and only after about an hour of "on the ground" time, plowing and then blading out fire lines, oil pressure drops to below the halfway mark on the dial, then suddenly bottoms out into the red, Stop light and alarms come on, I stop tractor activity (engine is still at full throttle), alarm stops, pressure comes back up (though not to the high position). If I continue working, this repeats itself several times. Once I report the problem, I'm usually called off the line and walk tractor back out to my transport, At walking speed, tractor does not display this behavior, and usually once shut down, and somewhat cooled, does not resume problem. Also, this has not happened every fire, only 3 of the dozen or so I've worked this year.
Any thoughts on what might be the problem?? I'm thinking possibly a bad/intermittent oil pressure sending unit, or possibly the wire to it has a short...
Thanks
Thanks
