some work pictures by BuMach
BuMach
The Netherlands
worked on a VT50 demolition shear last week. I think next week i need to line-bore the shear insert and crusher insert which have worn-out pivots..
20170321_124924351_iOS.jpg 20170321_124932123_iOS.jpg 20170322_114032900_iOS.jpg 20170322_155147970_iOS.jpg
BuMach
The Netherlands
also had a frame from a track-dumper which needed line-boring out the pivot point off the wheelsets20170207_161016930_iOS.jpg 20170207_161025045_iOS.jpg 20170209_190004495_iOS.jpg
Always handy a small enginecrane
also have put in some new TL lights in the shop, looks like daylight now:cool:
pretty happy with the results off just chanching the lights.. didnt knew it would make that much difference
BuMach
The Netherlands
made a adapter plate for a Claas tractor.
Owner has ordered the gearbox thinking he had a aftermarket frontlift (without pto) but he had a Original frontlift so the box didn't fit.
machined a plate for it and it just fit it, had only 2mm play left after grinding off a few spots.. so the owner got Lucky right there!
was actually cheaper to machine a plate with all the extra hours etc then to order a Original kit.. so not to bad at all.20170328_125219715_iOS.jpg 20170328_183213960_iOS.jpg
BuMach
The Netherlands
today i've been working on a smaller concrete demolition shear.
it needed some new teeth, had some new inserts machined and welded them in today.
hopefully i can get back on it on Friday.
the knife holders need some building up and i need to weld some spots when the shear is standing upwards instead of laying flat.
also i need to put some hardfacing on it again.
worked out pretty nice so far.
20170329_083201466_iOS.jpg 20170329_084752045_iOS.jpg 20170329_150915645_iOS.jpg 20170329_154219005_iOS.jpg
BuMach
The Netherlands
well guys gonna hit the hay overhere,i'll try to post some pics off the shear when its done.
hava good one and till next time.
Mink
Alma Canada
Machinist
Very nice work! What grade steel did you use on the concrete shear/muncher repair?
ship660
KC MO
I like how you use the stingers when welding. Makes for a very professional job just cut them off when done and edges are perfect. More people should be doing that as well.
StanRUS
Cal
Stingers, i.e. weld on-weld off tabs. Agree more welders should use stingers.
BuMach
The Netherlands
Hello Bumach. Very nice job and pics!
How many hours you need for line bored all holes on the clamshell?
Hi Mink,
I think i had something like 4-5 days worth off line boring. With this bucket i didnt do all the hinges on the clambs cause they where good.
To do all the points, incl the complete bodyframe and all pivots in the clambs i will take 2 weeks roughly.
A rebuild like this clambshell will take roughly 160man hours. With machine a few parts here and there.
Cheers
BuMach
The Netherlands
Hi, its Carcoxplus 400.
Its a bit in the middle off a Hardox 400 with the weldability of a Weldox 500. The shear normaly is a forged piece off steel with HB off 450+/-
We go down a bit on the inserts just to prevent cracks and 400 is hard enough to do a good job.
BuMach
The Netherlands
I agree to, i rarely see them being used while its so quick to set up..
Otherwise you usely get those sacked corners and you need to spotfill those up. Where usely on the edge(critical point) its not the best to start/stop the weld.
Its easy and quick to use.
jonno634
Garfield, WA
Farmer
BuMach, I came over from Tom’s thread and read your posts. Line boring has me intrigued, thanks for the photos and look forward to more.
