Kubota SVL 95-2 with AFE SS ECO Mulcher
verretro
Southern Louisiana
Is anyone on here running a Kubota SVL 95-2 with AFE SS ECO Forestry Head or know anyone running with this set? I have the Compact Track Loader and I just bought this forestry head, but now, have trouble locating the hoses.
No one around here has anything like this, or I should say running this set up. So my local dealership is having an issue locating the connections for the hoses. There is the Kubota Quick connection to basically connecting the end of the hose to the skid steer. But my dealership is having a hard time getting the information for what type of connection is needed on the end of the hose, to marry it to the quick connection.
So I would appreciate if anyone can give me some guidence, if they know, of knows someone who does know.
Thanks in advance
Tags
Connecticut
I know nothing about running a mulching head but I would think a quick call to AFE may be better than the dealer and you guessing. I do know that the less restriction you have the better, it will keep the hydraulics cooler.
verretro
Southern Louisiana
Thanks. I am dealing with Jon at AFE. They dont sell the hoses but he reached out to someone, so hopefully I can get something going quickly.
dneedelman
Santa Maria
Thanks in advance
If you were to bring this set up to the dealership do they have a hose machine? If not your local Caterpillar dealership should have a hose machine. It shouldn't be hard to figure out what size either JIC or British Standard Pipe fitting is on the AFE head. Be carefule when running this head on the Kubota, the cab isn't a sealed unit so you will end up with debris in the cab. I had a friend run a mower on a Kubota & cut through Poisin Oak & ended up in the ER since he was inhaling the debris.
JNB
North Texas
Flyin' low and rollin' slow...
On the SVL's, it helps to keep the filter vent on the rear deck behind the operator closed when you're running in super dusty conditions. It recirculates the air instead of drawing in fresh. The fan doesn't blow as hard, but it does keep the dust down a bunch.
dneedelman
Santa Maria
Good to know, my Cat D series is sealed up so I haven't had that issue.
f311fr1
Middle TN
You will need two 1 inch 4000 PSI rated hoses for high flow and one half inch hose for case drain. The quick disconnects are the standard flat face CTL couplers. Use couplers with female SAE O ring boss ports and flat face O ring adapters and female swivel flat face O ring hose ends. Any local Motion Industries ar Parker store should be able to help you.
pafarmer
Somewhere in the woods !
AFE can and will tell you exactly what is required and supply you with a detailed part number listing....confused ....I run AFE heads and they know their business well....ask for Jon and he will get you to the man in the know..
Tones
Ubique
Can someone what pressure the high flow curcuit on a SVL90 runs at.
Cheers
