Verycal Lift Skid Question
JS300
Texas
Power Plant and Cattle
I'm thinking about swapping a radial lift for a vertical but have a few questions first. I use the skid for general ranch work and it has been great so far except for drilling holes or driving post. When doing either it really takes two people to get the hole or post straight. Holes are fairly easy and not very critical. Driving pipe and keeping them straight is a real pain though. I guess my question is do the verycal lift machines really lift straight up and down or just "close", would it be a big benifit to me while driving post, and would I loose any performance in other areas?
JNB
North Texas
Flyin' low and rollin' slow...
Probably not perfectly straight up and down, but I've noticed a difference setting concrete culvert ends with my SVL90 compared to the radial lift Case I had. The vertical lift makes it easier to hit the mark. I think that Kubota's design also lifts a little further out at higher lifts for maximum reach when loading trucks. At least it feels like it does.
tmc_31
Merkel, Tx
Sports Lighting Contractor
JS300, I have a vertical lift machine (New Holland). I do quite a bit of hole drilling and find that I still have to move back and forth some as I lower the auger. I don't recall ever drilling with a radial lift machine so I can't compare the two. I have also used mine to drive tee posts and have had no trouble keeping them straight. Weather I am drilling or driving, I usually have a second person there to watch the bit.
Hey JNB, you get you a new toy?
Tim
tmc_31
Merkel, Tx
You bet I did! I saw a chance to get out of the Case and grabbed it.
I knew that you got a Kabota, I was referring to your Avatar. What is that thing anyway? Look sorta like a mulcher.
Sorry JS300, don't mean to hijack your thread
Tim
JNB
North Texas
Tim
Hahaha! I have no idea where I found that pic for my avatar Tim.
