Michaelh_2006
Has anyone else used ATF in fuel filter before??
If it is for an on road commercial vehicle I wouldn't do it the fines for colored diesel is high. Personal vehicle not so much a big deal. I have had good luck with the power service injector cleaner it is about the only product of theres I like but I won't use it all the time. Couple times a year in my old mercedes cars seems to keep them running smooth
I have an 82 240D and a 83 300SD
I do it when changing filters, and not calling you out TIO but i just did it last week on a 2012 3406 and it worked fine. I also put a quart in every tank on older diesels. I had an old IDI 7.3l I ran ATF instead of diesel fuel when I was working at a dealer selling alot of flushes. in the winter I would mix it 50/50 with diesel.
This test was done as a result of the low sulphur fuel causing stiction in newer engines. To get the sulphur low it strips the lubrication qualities from the diesel fuel. Sulphur in the fuel was never for ep lubricity like everyone thinks it was a contaminate.
