spitzair
Hello everyone,
I recently bought another Bobcat 732 that was advertised as having no compression... When I went to pick it up, the seller cranked the engine over to demonstrate the lack of compression. It was immediately obvious that the compression wouldn't be the issue, rather it sounded like there was no fuel or ignition. They had tried all sorts of things to make it run including installing new carb, new starter, new alternator, new fuel transfer pump, new distributor and all ignition components except for the ignition coil and a few other little odds and ends. I brought the machine home, started looking at it and found that if I sprayed something combustible into the intake of the carb it would fire but die as soon as the stuff was burnt up. So I decided to take the carb out, thinking maybe it needed cleaning. As soon as I got the carb off I noticed something odd, the gasket between the carb and the intake manifold was green and yellow with nutrition information written on it. Turns out it was just a cardboard box someone had sort of cut out to make a gasket with. They didn't even take the time to make the edges nice and smooth, just butchered it with a utility knife and called it good. They had made a few gaskets like this - the valve cover gasket which leaked profusely, the carb to manifold gasket as well as the intake manifold gasket at the head. The cardboard had all turned soft and mushy by now and so there were all kinds of leaks in the intake. I put some fresh gas in it, installed proper gaskets and the machine started and ran perfect! I've used it for a few hours now and it runs great, no issues that I can tell with the hydraulics or hydrostatics either, all in all a great machine! I just thought I'd share what I found, and maybe see what other kinds of fixes that didn't quite work you guys may have come across...
