S85 2000 Engine is over-heated
usedequipment
Viet Nam
Salesman
We have 1 Genie S85 which the engine is over-heated. We did check the engine oil and cooling fan. Everything is working normally.
Can anyone help us to check this problem ??
Regard,
tool_king
new jersey
road mechanic owner
If you have the Deutz 2011 engine .There could be a problem with the oil thermostat.It is under the the hex head plug above the oil filter housing .
Rozay
Los Angeles
Coordinator
the coolant level can be low. Have you tried filling the engine coolant?
usedequipment
Viet Nam
Salesman
Problem found
Hi all,
We have found the problems for this. Our mechanic had increased the idle rpm speed too high. That made the engine ran heavier and became so hot.
We have adjusted it to normal idle rpm.
