I have a 2000 Cat 248 # 6LZ00433 that's popping the fuse to the fuel shutoff solenoid. The relay was bad previously and I've replaced it, along with the shutoff solenoid. You may recall I had a reman engine installed a couple years ago and the solenoid didn't match the wiring harness. My mechanic direct wired it temporarily and I've replaced the solenoid and replaced the plug on the harness to factory. Machine starts for a couple seconds and then pops the fuse. There's nothing obvious I can see and the harness disappears down into the darkness. Does anyone know of any trouble spots where the harness might chaff?
