gcdoty
Hi, a couple of weeks ago I purchased a 1995 JCB 215 hoe. SN#434942. The previous owner passed away last year so no service history past along, so I'm changing all of the fluids and giving her a good going over. I'm a small time hobby farmer and this is my first backhoe. I'm not totally inept, I grew up in a truck garage and I was a factory trained Mack mechanic 40 years ago. But since then I have been a electronics tech.
I picked up a manual from E-bay and started gathering parts. The two questions of today are should the torque converter be drained when I change the transmission fluid and filter?
Second question, I know not to use dot-3 brake fluid, have some green IHM Fluid Spec 7308. Iron Gard Brake and Clutch. It is mineral based, I think it is OK but not 100% sure if I can top off the brakes with it.
Any help will be appreciated.
