butcherauto
Hi.
Looking for some insight. I have a jlg lift that I have owned for 10 years. This is the first problem I cant figure out. Lift will not raise from platform unless you start to engage drive to wither forward or reverse. You have to hold the drive just off neutral position either way slightly (not even enough to make lift move) and lift will only raise to 0 degrees or about 8 foot and then stops. It will not lift any higher. Also it will only do this much if you have toggle in high drive speed. Really acts like a low hydraulic pressure. As boom is extended out the lift will slowly go away due to more weight. Just didn't know if it could be electrical not telling a valve to open or close all the way or just a mechanical pressure problem. Any help greatly appreciated
