why would they offer their best control system in an economy machine?
so after a few hours in the bobcat i have things to say. i am happy with the mechanical part of the machine, i was surprised the boom has mechanical "snubbing" on it. the software on the joysticks seems to be about as good as they might be able to get. what i am not happy about is joystick placement and joystick effort. it takes way too much effort to run the joysticks. the jcb joysticks were effortless, and that is the way it should be. i don't know what is worse running the high effort joystick or running mechanical controls. also, the joystick placement is bogus. sure they slide forward and backward; but all that really does is stop the lap bar from interfering with them. the relationship between my hand, the joystick, the base of the joystick, my elbow, and forearm is all off. jcb had the ergonomics figured out, that machine fit me like a glove. it was setup just like an excavator. in the bobcat i pretty much have to run the joystick without an armrest, and that is not the way it should be. i looked to see if there was anyway to adjust the joysticks further and everything pretty much seems to be all welded solid. if i slide the seat forward quite a bit things get only a little better, but i am not willing to give up the legroom. maybe i shoulda looked at a cat, but they do not have the v shaped belly pan, and they are harder to get in and out of.
