Joeyslushr
I'm just circulating water thru 1000' of pipe. I want the mass of 50* ground under the floor.
The guys I've talked to up here tell me the larger mass is more efficient, evens out highs and lows. And as I said before wet sand would do a much better job of transferring heat. If a guy could figure out a way to keep a consistent moisture content under a slab, you'd be on to somethin
I would never put pipe in the concrete. Concrete moves, ive been in plenty of shops that the joints have opened up. A meat head sawing joints or a joint opening up a lil to far rupture a line and then u have a real problem on your hands. I know there's lots of studies out there but I'll take common sense over studies any day.
