Fordman
So you may remember when I posted how my 350B wouldn't come out of first, and wont go in 2nd or 3rd. I took the transaxle to the local case dealer to get rebuilt, and they did it. But Now I see the problem... The first gear on the input shaft has a flat side and a protruding side. The protruding side was installed away from the gears putting the gear farther out in the case(1st photo,Pulled off shifter in 1st). the 2nd photo is before dis assembly. What would you do if you were me? Would case take it back and do it again? Could I get by for the moment with 1st the way it is? Im gonna call him on monday would like been there done that opinions, thanks.
